RobbieO
 - Sacramento River Delta
 - 212SE
Keep the shoes off the Seadek!I received my 2021 Yamaha 212XE at the end of April and have taken it out four times (three of which were this past weekend). I also have the blue and black color scheme, which gets a lot of compliments on the water. Although I don't have the Drive model, I'll provide a couple of my thoughts on the new boat.
1) There does seem to be a few fit and finish issues like the OP stated. For instance, the gasket around the rectangular area for the clean-out ports on the stern looks like it was put on by a four year old.
2) My stereo doesn't sound as loud as I expect and has a noticeable hiss when there is no source to the stereo, or the audio source is paused, and even when the volume is turned to zero. Perhaps the speakers are wired out of phase?
3) My cleanout ports get water in them too after a day on the water. I've heard this is normal, so I just drain them after I pull the boat out and then put them back in. Not a concern for me.
4) I too have a lot of metal filings and fiberglass that comes out after a day on the water when the drain plug is open. I expected that. I may try and flush out.
5) I'm still trying to figure out the best place for a cooler. Unlike my previous boat, this boat doesn't have an integrated cooler under the rear seat. Putting the free cooler that came with the boat in the storage area in front of the passenger seat doesn't seem convenient when it's full.
6) How do you clean the Seadek? It seems to get dirty fast, especially on the rear of the boat.
7) I'm very happy that I was able to get the boat to fit in my garage and under my 8' garage door. I had to take off the wakeboard racks and I also had to lower the tower lower than the cable would allow by unscrewing the cable holder from the wakeboard tower, but I'm happy it fits when needed (picture below)
8) I can't seem to get the ratchets for the factory cover to be in the right location when tightening to actually allow their zippered area that is supposed to enclose the ratchet to fully close.
9) I haven't really pushed the boat because I'm still breaking it in, but I did open it up once this past weekend now that I have a few hours on it (which according to the manual is acceptable). I hit about 44mph with four people and coolers, etc. on board. I expect it can go faster according to everything I've read. I'll try on a calmer day with less people on board. If it doesn't go faster than that should I be concerned?
10) Does everyone else have a hole (that is finished) in the very front of the keel (as seen in picture below)? I've never noticed that on other boats. I think it's to drain water from the anchor locker? But I would assume it could also let water in.
11) I was surprised the radio didn't have an equalizer or balance/fader controls. Just the zone controls.
12) I'm still trying to figure out how to use the wakesurf/wakeboard settings. Can't quite figure out how that works. I've used the ballast and also the Wakebooster once. Still learning how things like the cruise control work.
Dek Magic SeaDek Cleaner
You love your SeaDek. We knew you would. We also know that life happens, and with life comes mess. That’s why SeaDek created Dek Magic, a cleaner specifically designed to keep your SeaDek looking like new. So next time life happens on your boat, breathe easy — We Got Your Dek   Some stains are...
