22 SX195 Bimini Pole Diameter
Thermobrett
Lithia, Florida
SX195
Ordered some Jetboaters.net shirts and a flag from @Island Jay yesterday. Does anyone know the diameter of the rear Bimini pole so I can order the pole mounts for the flag? I’m not hip on using zip ties to hold it on.
just measure the place were your gonna install... could be 3/4, 7/8 or 1"
Thanks, I don’t have the boat at home to measure. I was looking at these and they seem to be about the sizes you indicated it could be.
Flag Pole Rings, Flagpole Rings Aluminum Alloy 360° Rotating Anti Wrap Flag Mounting Spinning Ring Clips for 0.75-1.02 Inch Diameter Flag Pole- Pack of 2 (Matte Silver) https://a.co/d/aulJzOT
Just measured mine, it's older but I'm pretty sure the same size. .9"
Thanks! I think what I found will work, and rather inexpensive.
What did you find?
Oh and BTW, don't use your anchor light as a flag pole. ;)
I was going to go with these.
Flag Pole Rings, Flagpole Rings Aluminum Alloy 360° Rotating Anti Wrap Flag Mounting Spinning Ring Clips for 0.75-1.02 Inch Diameter Flag Pole- Pack of 2 (Matte Silver) https://a.co/d/hSCAj1g
Pretty sure the tubing diameter is 7/8", it was on our AR230. Easy to measure the circumference then divide by ? or 3.14. Our sailboat with a wider 10' frame is 1" s.s.
.9 measured above by @oakley24 is pretty close to .87" or 7/8".
That’s why I love this site, everyone willing to help one another!
Sidebar…FYI, Glad you referred to it as a pole, not a pipe. The pole is actually tubing, not pipe. Tubing is measured by outside diameter, pipe is measured by inside diameter.
I like the clarification, ID vs OD can make a HUGE difference. I do the clarification to people when it comes to fishing. When someone asks for a fishing pole, you hang a flag on a pole, and catch a fish with a rod. Maybe it’s a Midwest thing lol
yep!!! 1 1/2 sched 40 aluminum pipe is 1.900 nominal OD ~1.6 nominal ID exactly the material my wake tower is made out of and if you take 1 1/4 shed 40 alu pipe you can turn it down to 1.600 and make plugs to weld pipe together...
made these for a big power catamaran the other day.. had to have then NOW and then gave me the wrong length... had to add 20" LOL so much for doing a friend a favor LOL
attachment - 2022-12-03T085720.580.jpgattachment - 2022-12-03T085751.217.jpgattachment - 2022-12-03T085800.167.jpgattachment - 2022-12-03T085810.773.jpg
That’s what I was thinking. I think the pole clips will be to cumbersome when dropping the Bimini for storage and may bend the frame pole a little
What did you find?
I saw someone with a 252SE using the anchor light as the flag pole. Perfect size and location but I was second guessing if it can handle the constant fluttering of the flag. Why do you say not to use it?
