Hokietechvpi
- 242X E-Series
Done
Can I get one of these please ! ?I have a 2018 242x with the cracked glove box lid. I am considering making a 2d model of the lid and getting parts made out of 0.5” plastic. The part is slightly curved, but I think a flat part will be good enough. I can easily get 0.5” clear polycarbonate material waterjet cut. Finding a black shiny material that matches will be harder, but I’m looking
Has anyone tried this or interested. The parts get much cheaper with more people. Five people would make parts ~$50 a piece, vs buying the entire glove box.
Let me know if anyone is interested.
Russ
I'm in...mine got cracked too!Ok, I worked on Measuring my Front Panel tonight and made a drawing. Please check your glove box lid size against this drawing. If I buy one for myself, it's $200, If I buy five of them , they are $45.30 a piece, plus shipping and taxes, and they get cheaper from there. I think it makes sense to buy 5 right now, and install mine and make sure it works. I can then mail who ever wants one, and venmo me. A few extra isn't a bad thing, then I can play with baking one of them and try to match the slight curve in the part.
If others want one, we can do another group buy. I can get the holes built in for the magnetic clips, but the hinge will have to matched drilled by hand. The part will be 0.5" clear lexan, which you can paint with plastic spray paint.
Do you have any of the glove box doors left? Mine got cracked the other day.I have one more. But can always order some more. PM me your info.
Mine cracked on my 242S a while back and would be in on purchasing one if available.I'm in...mine got cracked too!
Well, the last fix didn’t work, but I think I’m on to something now. I stripped off all the hardware and rubber mat and—this is key—used a 2-part plastic adhesive to rejoin the pieces. This creates a chemical bond between the broken parts, and it feels really strong. Then I used a Dremel tool and cut grooves in the acrylic perpendicular to the cracks on the backside. I filled those with the 2-part adhesive to improve strength of the repair, almost like stitching between the pieces. Don’t worry—when you replace the rubber mat on the backside it is covered. I used spray adhesive to reattach the mat, and you can’t even notice. Now the scary part—I used a palm sander on the front surface to completely smooth the repair. I plan to use high-gloss acrylic paint to mimic the original finish, but it’s possible a wet sand could work as well. I’ll update after final but posting a before paint pic…
Not sure who this post is directed to but I have a used one from a 2017 for sale. See my August 25 post above of interested.Looking to order one as well
If you have any remaining
Let me know if still available-Not sure who this post is directed to but I have a used one from a 2017 for sale. See my August 25 post above of interested.
Note: I’ve just reduced the price from 1/2 retail to 1/4 retail part 48 in the screen shot. So about $232 plus actual shipping and package costs from 94505.
View attachment 211131View attachment 211132
We did make one for a customer and still have the part file in our system. We could do it again if needed.Did @JetBoatPilot end up making a piece to cover this? Our door broke as well. Hoping some sort of adhesive will work if we cannot find a replacement.
Hi JETBOATPILOT, I also have a broken door and need a replacement for the 242. If able to produce I am certainly interested.We did make one for a customer and still have the part file in our system. We could do it again if needed.
