I wonder if the idea is to keep fuel readings more accurate while cruising because you'll be consuming it much faster than at no wake speeds? It's not like a car that rides level all the time except steep hills.
I've noticed the fuel gauge doesn't vary much when crossing wakes and bouncing the boat around though, just dropping off plane when the fuel is lower it really changes. Also when I filled it, and at the dock it showed 100% but 5 minutes later on plane it's dropped to 95% which isn't practically possible to consume that much toodling out and then taking off.
Either way, I tend to fill up so I don't have to worry about fuel for the day...never know when we might decide to go somewhere or do something different and it would suck if we said, "30% is enough to go out for today" and then we can't go.
