- Northern Vermont Lake Champlain
- Boston Whaler
- Other
Some of you already know that we built a Timber Framed Home on top of a hill overlooking the Champlain Valley in 2001. I have posted some of what we see, the Lake, sunsets behind the Adirondacks, etc. What you may not know is that all the timbers for the frame were once trees on our property. I hugged, feld, skidded all of the Red Oak, Black Cherry, Maple, Ash and pine out of the woods with a winch on the back of my tractor. Before we bought a winch, I used (2) 20' lengths of 3/8" chain. Once out of the woods I would cut up the tree to useable lengths per the "cut list", requiring 20'+ timbers, posts. Some trees are straight, others are bent. We try to straighten out the bent logs by cutting into shorter lengths for uses as knee braces and short timber pieces. I try to pick the straight ones, for my Woodmizer LT40hd-D42 sawmill with 21' bed, because although you can cut the bend out of a log, there are still a lot of forces in the "cant", a squared off log, that will show as twist or bend in multiple directions, once the log starts to dry. So I cut about 10-15% over the cut list. All the joinery was done by Liberty Head Post and Beam Co. Below are some of the pictures of the build.
I have a lot more pics of the build. The next step was getting the frame closed in and the chimney built. All of the stones for the chimney were picked from stone piles that previous settlers had stacked just after the Civil War to clear the fields. Futile efforts on a place named Hardscrabble Hill.
