shanes17
- Lake St Louis MO
I actually had an xm antenna I was using on the fiberglass, but I swapped it for the little black magnetic puck, as it’s easier to move around in case the tower is blocking it.
Don’t worry about the elements, as these are designed for outdoor use and to be stuck to the roof, trunk of a car. I leave mine hang loose out of the GPS antenna just in front of the starboard side windshield. It has slack so I can adjust as needed.
So you used the antenna that came with the SiriusXM SXV300v1 kit? I am curious how you got the wire from the rear head unit up to the starboard side, and the antenna cable that came with the kit was long enough to reach that?
Sorry for all the questions, this is one of the first projects I plan to tackle this Spring when we get the boat out of dry storage.
TIA
