Advice on repairing gouges in tower
Pinhacker71
Verona, KY
242 Limited E-Series
image.jpeg I took off my racks to replace them with swivel racks and a kneeboard rack when I noticed these deep gouges in the tower. I smoothed the burs off with a dremel so I don't cut myself again. Should I fill with JB Weld, sand, and paint with a textured paint? Any suggestions. Thanks in advance.
I assume the new rack won't sit over the scratch? I'm not sure how it would match up, but Plasti-Dip is very good. Here is a picture of what it looks like when it dries.
That's a hard one to paint and make it so it doesn't stand out.
Maybe apply a band of black 3M grip tape over the scratch. Put a matching band on the other side to be symmetrical.
I wish I could just cover it up with the new racks, but the rack is 1/2 inch to large for this portion of the tower. Matching racing stripes on each side?
I might see what Plastidip looks like. Always reversible.
Walmart also sells crinkle paint. Would look the same and not wear off.
I actually like the stripe accent idea, maybe in a color!?!? @Murf'n'surf
Can you get a smaller attachment mount from your rack manufacturer? Then you may be able to put the new rack over the old location.
When I bought my rack a few years back, I originally ordered the incorrect diameter mounting bracket. A couple quick emails to the rack manufacturer and a week later I had correct size mount and sent the original one back.
My wakeboard racks came with rubber inserts that adjusted the size to whatever I wanted. I would probably buy some rubber to make it fit on the smaller pole. The rubber also grips it well.
Cover in pool noodles?
I know I have seen one like that before because of the way the racks would go to swing out of the way and the tower laid down.
Sadly, doing a search "pool noodle mods" just brings up a bunch of Yamaha boat pictures from people's signatures.o_O
I had ordered the monster swivel racks. They are too big for the rear rack mounting area. I'm going to order a different set of swivel racks for the 1 7/8 rear tower mount. Gotta return the monsters but that's ok. Thanks for advice. Monster swivel racks were too bulky anyways. Too many parts that made it kind of wobbly.
