Amplifer mounting help!!
jeremy6112
New to the form..
I'm installing a stereo in my 2020 ar210. I have two amplifer that I'm going to be installing. Question is what is my best option to mount them? I'm going to be putting them under the dash where the stereo is located. Picture would help of your install to give me some ideas. Thanks in advance.
Here are a few pics of my setup. Search for amp or electronics placement and you should find a few other setups. The two most popular locations for amps seem to be under the helm or close to the batteries.
My installer put a 900 and 400 JL amps in the port helm compartment, attached to the back of the seat area. They're out of the way and I barely notice they're there. LMK if you want pics.
Thank you.. looks good how you hooked it up. How did you attach the board to the fiberglass?
I have an 18 AR210 and installed the amps in the helm area where you are considering. When I added a second amp for the sub, I made a board to attach some of the wiring setup and this is attached using wing nuts for easy removal if needed.
I used stainless steel hinges to mount them to get easy access if needed. The boards get heavy to hold and screw. I used the 2 bow cushions and the engine step cushion stacked up and then set the amp board on those and it lined up perfect for me to screw in.
