GiddYupJoe
- Beavercreek, Ohio
- Boatless
- NA
- X
- NA
I only ask because it always seems to hit around 100 hours. Mine was 99!
Damn I hate to hear this. Have you see if it is cracked or/and is the bolt sheared off?About 80 hours.
one of mine broke on its maiden voyage in my lake when I got it home... go figure.. it was fine on the test drive in OK.
I bought all the bolts/gaskets to replace it.. not leaking oil.. so hopefully that will cure it.. 58 hours on mine.
I oredered the factory bolts from Yamaha..
hat is exactly right. The thread from the other forum goes into great detail about the strength of different types of replacement bolts. I believe CaptKev did a great deal of research on the replacement bolt.My understanding was that people who were replacing bolts were using stronger bolts than the OEM parts. It also appears from reading old threads that in 2012, the 3rd bolt down was changed to a larger bolt that does not fit the 2010 and early 2011 model oil coolers.
Ive also read a lot of people have simply removed the offending bolt that was over torqued and replaced it with a factory one and had no further problems.. mine is not leaking oil, and there is not damage to the cover, so I am just going to replace the bolt and watch it.. I would rather break a $2 bolt than a $650 oil cooler.
%$#@! Big vacation trip coming up and parts back-ordered at Yamaha.
