michaeljbenner
Hello all! I have been lurking here for a couple of months to see what I was getting myself into, then 3 weeks ago, I took the plunge! Bought a 2008 AR210 that looked to be in great shape for its age. Turns out it only had 79 hours on it (Yay me! and thanks for everyone's help locating, purchasing and hooking up the YDS cord and software!)
Anywho, the next item on my list is that pesky scupper valve that Yamaha pinched pennies on. I bought the recommended SS replacement from Amazon ($56) and started digging into it. As been experienced before, as soon as i tried to remove the old scupper, sure enough, the ring popped right off the body. Gah! Glad I am tackling this now.
What I realized from reading all the different scupper replacement threads, that the hardest parts are getting a wrench on the nut (easy fix with this: Adjustable Wrench, 16-68mm Lightweight Aluminum Alloy Large Jumbo Adjustable Wrench for Bathroom, Short Handle Ultra-wide Jaw Opening Spanner Slip Nut Wrench Set Tool for Removing, Tightening Drainage - - Amazon.com ) and trying to hold the outside flange to get the nut on. The original valve from the factory has these slots in it that you could stick something in to hold it still while the inside nut was being tightened:
Taking apart the new SS valve, I realized that there was a little metal tab on the interior under the rubber flap:
That's the ticket! Stopped by Home Depot and picked up some PVC Parts to make a custom wrench:
The 1" sweat-to-threaded fitting fits perfectly inside the inner ring of the valve. This provides person #2 on your install to apply lateral pressure on the valve and sealant from the outside while person #1 tightens the interior nut.
The PVC male adapter screws into that piece, and then you have to do some fabricating to get it to engage the metal tab:
Add a line to mark top-dead-center:
That's it! Took me about 20 minutes to make. This should allow person #2 to both push the valve into the boat, hold it firm and stop it from twisting when person #1 is tightening the interior nut. Hopefully this will make the job a ton easier.
