- Royal, AR
- SX
That would be awesome!!! I sure appreciate that. I need 2 of these. I'd like them in black (tough decision). if you have enough material. I'll PM you..
Can the center hole accommodate an 8mm bolt?
$20 and I will send three just in case one gets broken.
I had the center hole at 8mm. I can open that up to 8.5 or 9 if you prefer. You can run a drill bit through the hold if you need to make it larger.
