dshscarab
- South Florida
- AR195
I took it out yesterday. This time, I had four (4) adults including myself and a small cooler. The top was open, water temp was 89.3 degrees. The waves were around 1/2 foot. Top RPM was 7245. I will check the cone again. I do remember when I installed it, I was able to find the "T" marking. It looks like it is centered. I had previously purchased trim tabs for the Scarab 165 ID when I had it. Due to not having room to ever install it. I never did. I did install the tabs on this AR195 a few weeks after purchasing the boat since I already had them and threw all the boxes away. They are at a negative angle when not deployed but do you suppose they could still be causing some type of drag? Would it affect RPM as well or just top speed?
