AR195 - How big of a boat lift to get?
80sarcade
AR195
Just purchased a AR195! Now I need a boat lift. I am in Indiana and looking at a Lakeshore or a ShoreStation. Going to do a vertical lift, maybe do electric - 12v solar.
The boat is listed at 2500lbs. What size lift should I be looking at, a 3000 or 4000lb lift?
It will be in about two to three feet of water, sand bottom and relatively flat.
Thanks Paul
Dean P
Chaparral
VRX
Thanks Paul
Just food for thought but I'd purchase a lift based on your next boat. There's a good chance you'll upgrade in a couple years and don't want to have an undersized lift. You should at least plan on 2x the boat weight loaded with fuel (gas weighs 6 lb/gal.) and equipment. Good luck.
tabbibus
Lake Lanier, GA
Agree with Dean. If you cut it close and then get a bigger boat, gotta invest allover again in a lift. I went 6k lbs on my lift, boat weights 3800# dry.
Matts18
East Tennessee
I would go for a hydraulic lift rigged to a deep cycle 12v battery and solar charger. Go with at least a 5000 lb lift so you don't have to buy a new one when you upgrade boats.
d_coyne1984
Chanhassen, MN
I just upgraded to a wake boat and am damn glad I bought an oversized lift for my Yamaha. I have a 120" wide 5000lb Shoremaster and it has served me well over the past 5 years. Their customer service has also been really good and easy to get a hold of. My new boat is 4200lb dry and probably right at that 5000lb fueled with gear. They were really good about reassuring me that the lift was safe for that weight and that the boat and bunk placement was properly set.
I highly recommend getting a canopy or a lift with the drop-down side curtains. I leave my boat uncovered (mooring cover) over the weekends and then put the mooring cover on during the weeks when I am away so it's double protected. The interior stayed really clean that way and it really helped protect he gel coat on my Yamaha. My 4 year old gel coat looked almost as good as new when I sold it. I purchased the extended canopy supports so that I never had to drop my tower. My canopy is 23' which was really about perfect to cover the entire boat with overhang on both ends.
If you want to save some cash, it's really easy to use the hand crank on boats as light as the 19-21ft Yamaha's. I may be upgrading to a power winch here with my new boat though.
20180623_185445.jpg.
80sarcade
AR195
My next boat will more then likely be a pontoon boat. So probably a new lift anyway. 😀
d_coyne1984
Chanhassen, MN
I think most vertical lifts can be easily converted by swapping out the bunks. Something to consider rather than replacing the entire lift. Pontoon boats generally are pretty light so you could probably get away with a 3000lb lift to cover both boats unless you are talking a 25' luxury tri-toon with a 200hp out back. I would look for a 4000lb just to be safe though. I think our 24' Premier twin-tube with a 115hp weighs about 2300lbs.
80sarcade
AR195
Having a 4000lb ShoreStation delivered Friday. I did go for the bigger per folks suggestions. Thanks
Doublej_k
Old post, but I need a lift for my 2019 Sx190. What inside width do I need at minimum? My slip is 10 feet wide so can’t get a huge lift.
biffdotorg
Pelican Rapids, MN
Other than the "yacht rated" 275 series, all Yamaha boats are 8.5' wide or less. Width is the least of your concern. You do want enough room for guide poles, but not so wide that it's hard to board the boat.
I actually have a dock section in front of the bow with bow stops, as when the boat is lowered, it's the easiest way for guests to get on is over the bow steps. Purchase your lift by weight and go from there. You will be good with a 10 foot wide slip. Good luck!
gallobg
MasterCraft
When I had my AR195, I bought this lift and it was a perfect fit. Total width was just under 10' wide. Should help you gauge what will work from your local lift supplier.
I had the V45-108-66/78 version.
