AR210 No Thrust.
Rich Paradis
When advancing the throttles on twin jets I only get an increase in rpms no noticeable fwd or reverse thrust. Can anyone advise what may be going on. It happened on both motors systems and they worked perfectly before …
JC6275
Clifton IL.
LS
Civication, check your impellers for debris lodged in them.
djetok
Edmond, ok
Clean out plugs locked in?
Dough
Lake Barkley
Limited
Put your plugs in!
Trevor Shipman
Charlotte, NC
Gotta be the plugs. Make sure both engines are spitting water too (starboard side).
Rich Paradis
Thanks … I think you nailed it … prior to taking it to lift I checked plugs to be sure they were down nd locked … heard boat won't run if they aren't. Boat ran beautiful after installing new wear ring .. rpms and throttle positions matched beautifully … nice thrust … then next time someone went to take out no thrust .. suspect someone inspected plugs and didn't get them in right.
@Rich Paradis glad to have you on board,
be sure to look at the link in my signature below for common issues with your boat, especially the scupper valve,
Cobra Jet Steering LLC
that was an easy one
