Dean P
- Florida
- Chaparral
- VRX
As I've always stated, I like to make my life as easy as possible and still get the job done.
Cause my boat is on a lift I thought I could take advantage of the pilings holding the lift and roof. My idea is to add sprayers to each piling pointing at the boat. As the boat is lifting the sprayers will be "on" rinsing the boat as it passes by. This is pretty much the same as I do know with a garden hose. I know it's better to brush it but that's hard to do when it's on a lift. Liking the idea so much I picked up an electric valve which I control thru WiFi. Now, I can turn it on when we're still on the boat not allowing anything to dry. Another advantage is when I go out on the boat, I programmed the app to turn on for 5 minutes to rinse the cradle. Salt on anything eventually eats thru everything. I've yet to try it on the boat as it's still at the dealers. ?
I finished it up over the weekend and I think it came out pretty good. I added a booster pump to help with the pressure (although I could still use more) and it all works. Here's a couple pics of it off and on. Let me what you think. Is it marketable?
