Jets4Fun
- Limited S
Hi Guys!
I haven't posted here before but wanted to share my super exciting weekend with you all. We have a 2012 242 Limited S with about 160 hours on it. I really hadn't any idea on what was going on and proceed back to shore to find the boat almost filled with water. The port side clean out plug was dislodged and the tube was caved in. The port side engine cut out during this and yes it filled with water also. I had some problems with the plugs the day before but really didn't know this could happen. Kinda figured out the issue with the plugs and will be doing the rebuild on them. The problem I am having is the port engine now will not even turn over. I have removed all spark plugs and drained out the water from there and pumped all of the oil out of the engine. Removed the intake and cleared out the head and intake of any water also. Has anyone on here have some advice on what to do next? The port rpm gauge is also acting different, when you try to turn over the engine I get just a click from the starter. During the start up on the gauge it runs up to 4000 rpms and the stops there shortly and then goes to the full start up procedure but still wont let the engine try to turn over. Please let me know if this is something any of you guys can help me with.
Thanks,
Thanks,
