CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
success.
water tested the replacement sensor today. air temp 72*F and water temp 62*F
after adequate warm-up, it took about 5 miles of WOT to get an overheat. port engine trips the 266*F mark before the starboard engine does, but both showing about the same temperature on the YDS. i love having two of everything on these things for comparison! the overheat did not cause it to go into limp mode, just louder with loss of power. temps would quickly drop with the throttles placed at the detent just forward of neutral and the tripped sensor would reset with the ignition key. the engines were ready to go another run in about 30 seconds - the old sensor would take what seemed like forever to acclimate. did a few WOT passes with the similar results. chalking it up to just running them hard along with 10years of build-up inside the engines.
during the summer, water temps get into the low 80s here, so i'm inclined to believe this will quicken overheats at WOT. but i had success making long runs the first season (i'm assuming the sensor wasn't bad then) if i kept the engines around 9000RPMs. i'm also going to be conscious about making those longer runs with the blowers going.
