jcsmith77
- Harrisonville, MO
This is solely for our surfing setup. So i bought a kit for hard installing ballast for my boat from wakemakers on their black Friday sale. My plan is relatively simple to run one pump to fill the two bags under the port seat and then still use my over the side pump to fill the one on the swim deck.
My first dilemma is whether to install the valve off of the thru-hull under the exhaust water box; so would i really be safer with it that hard to get to? Or should i just find a fitting that will thread onto the thru-hull and go straight to the hose?
The second question is do i trust a plastic fitting with or without the valve?
Looking for peoples experience or expertise. I have other questions to follow but this is where I need to start.
