Boat Stuff Ballast Pump Jumper Cable
Rodder77
Cambo - I need one of these for a 2016 242x E. similar to others, pump runs fine and fills and empties however one bag (port) says empty on connext however is about 20% full - need to empty so it sync's with the connext. please advise - thanks!
Cambo
Long Island
Sending pm
Dornbox
Freeport Maine
212X
That’s exactly how I used mine. I either hit fill until it thought it was full then used the jumper to fill actually them, or did the reverse. My connex still doesn’t fill or empty them right though so I find myself using the jumper to top off or completely drain my ballast bags anyway. Super handy!
B Young
212X
This is mainly for the 2016 - 2022 boats with factory ballast it could possibly work with other models or be updated as I get more info on the different configurations .
It works for the 21,24 and 25 foot models see price listed below for the different models.
  • Over ride and power up the pumps to drain water or fill to the max if the timers get out of sync with what’s in the bag.
  • Expand the system using plumbing fittings to allow the stock pumps to fill the transom bag or other bags eliminating the need for a tsunami or other type of plug in pump. I run two feed lines into the bag so it fills twice as fast.
  • Winterize the pumps by sucking in non toxic anti-freeze then discharging it so the fittings and bags don't have any water that could freeze and cause damage
  • Check the pumps operation to trouble shoot a faulty pump
  • Fresh water flush out if the boat is going to sit for winter storage you can flush out the corrosive salt water for longer pump life
  • Easy to pump out residual water that may be in the bag especially the center locker bag it tends to accumulate water due to a siphon effect and will end up 20% to 40% full
  • If your lake requires ballast to be flushed for cross contamination this will make it easier
Using this cable you can watch the bag to observe when it’s full or empty
This project was created by my 14 year old son all proceeds go to his sailboat fund . He likes the power of the wind I like the power of the jet drive
Price for the cable is $73.00 + $12.00 shipping to the lower 48. Includes detailed directions for optimal operation and labels for the pump connectors
Price for the 21 foot models $73.00 + $12.00 shipping
https://jetboaters.net/threads/2017-yamaha-242xe-mods.19753/
We finally tried the cable and the pump didn't run. We checked and realized the the fuse blew in the cable. Maybe we need a new pump?
Thanks Bob
Cambo
Long Island
The pump could be defective. A good way to troubleshoot is to put a new fuse in and test another pump and see if it works. If the fuse pops than there is a chance something else is wrong. Keep me posted.
