Boat Stuff Ballast Pump Jumper Cable
Could you please PM info to me for a 2019 212x? Thanks.
My 2018 242X is plagued with ballast issues and Yamaha can’t get it fixed and says the part I need is on backorder for over a year. They installed 3 new pumps but now says that’s not the problem that I need a new “Switch Control”. Of course this part is on backorder for who knows how many years because of “Covid” the dealer says. I’m looking for a way to be able to get our family surfing ropeless this summer. Could this or anything else you have for sale help me get our ballast system finally working? Thanks!!
You can get this to control the pumps but will need to watch as they fill due to not having overflow drains
Yamaha switch controller kit for stock ballast pumps | Jet Boaters Community Forum
or use the pump jumper cable and have to plug into what pump you want to run to fill or empty. The switch controller was designed for your exact issue failed switch control not under warranty they are about $650 and don't even work that great to begin with
let me know if your interested I can send pay pal info
So the $47 jumper cables system will get me working again? Just connect to battery clip it into the pump and then go to connext screen and hit fill? Then drain on screen at the end? Or you don’t even use connext? If not how do you drain? Thanks!
The pump jumper cable gets hooked from the battery to an individual pump to either fill or empty that pump. The polarity is changed to energize the pump to fill or empty Connext is not used.
If you’re using Jabsco water puppy pumps you can buy the harnesses, switches etc from Wakemakers Wire, switches, connectors and electrical accessories for installing ballast systems
Yes you can but there is more to the system its not quite that easy Im not going to get into the exact details of why. Then you have the expense since they don’t make a boat specific kit Your buying oversized cables and they use good marine wire same with the kit that I sell, that wire is not cheap. My system is plug and play and costs less then if you buy all the parts separate its also boat specific. The 242 and 212 require different kits.
The other issue that happens if the timer is having an issue it throws a code and disables the speed control . The speed control is a critical part of water sports.
@haknslash From memory you set up a complete after market kit when you had your yamaha correct? To do this you need very good electrical and mechanical skills that you most likely have.
He had created a new thread asking for help to get something setup since his stock wiring or Connext etc is not working https://jetboaters.net/threads/2018-242x-ballast-system-not-working-need-help-advice.36717/. He included a link to this thread where I see he’s basically asking for the same kind of help or info. His dealer and Yamaha are jerking him around so I was offering a way to by-pass whatever Yamaha has done. I didn’t know you sold kits or whatever. I did not read this thread but rather came here from his link in the other thread. I don’t care where he gets his stuff or anything. Just saying he can by-pass Yamaha’s stuff if he wants to actually use the ballast system on his boat. I didn’t even realize this thread was in the classifieds and it’s your ad to sell stuff lol. Apologies, I’ve deleted my post and carry on.
@Cambo id like to purchase the cables! Please shoot over your info for payment and details on shipping / timing. Thank you!
Hi Dom what model boat
@Cambo I’d like a set if still available. 2016 242XE.
Sending pm
Sending pm
I'd like to order one... I am having trouble with my center ballast bag. This is a new boat for me and I have warranty, but I'd like this on hand for any future issues...
2020 242X
please send me info on how to purchase.
Thanks
Is the center bag filling with water ? sending PM about payment info
2 trips ago, the center bag filled about 50% and would not do anything else… I ended up draining it manually in the bilge. Last trip it would not fill or do anything… I have not tried to diagnose yet. I’m a newbie to jet boats and anything to do with surfing. (Although a long time boater/owner. Any suggestions are appreciated.
The center bag has a tendency to fill on its own from a siphon effect due to that one being at the lowest point.You can also fill them to the max using the cable the auto fill empty is a great idea but there are to many variables that dont let the bags fill or empty all the way. If you plan to surf this site is loaded with info needed to get a good surf wave enjoy the boat they are great.
Can I I would like to order one of your jumpers for my 2021 212xe. Can you please pm me the instructions? Thanks.
Cambo,
I’d like to order a cable for 2018 242x. Center bag filling, having to manually drain occasionally. Thanks so much!
Cambo
I’d like to order one for my 2019 212x. Center bag isn’t draining all the way and now overflowing. If I understand this correctly, when the boat is off if I hook this up it can drain it all the way?
Yes this will allow you to fill or empty any of the ballast tanks with the motor off. I will pm you the payment details
