Ribs77
- PNW
You need to add an onboard charger. The charging system on your boat is not capable of properly charging your battery.
IF you’re going to stick with a single battery you need a dual purpose start / deep cycle battery.
IF you’re going to add a second battery, search the forums and there is a ton of information. I personally like the BEP marine switch that comes on the Yamaha boats, its compact and simple, start & house battery switches plus an emergency parallel switch and the dvsr is built into the cluster.
Question about this.
I don't have access to an outlet at my wet slip. An onboard charger needs to plug into external power, right? I have a NoCo charger/tender, but for the offseason when the boat's in a barn.
What should I be doing during the season when I'm in the wet slip?
Edit: I always carry a charged jump pack.
