Battery recommendations
when going single battery, go deep cycle or at least hybrid. A deep cycle can handle the charging cycles and heavy drain better than a starting battery
Well if given the choice would deep cycle or hybrid be better?
Deep cycle. It's not like you are cranking over a car engine. Everyone has an opinion, but I have used a deep cycle for start and house in my yamaha for years.
Believe it or not, I did the same in my fishing boat, and that 40hp outboard needs more juice than these waverunner engines. They turn over easy.
I appreciate that. Enough people have said Deep Cycle is enough and I've been good with my Group 24 starting battery thus far, so I'm sure going to a Group 31 deep cycle will be fine.
so what would you guys say to those 2 batteries for SX240? I am really liking Li IOn option so save weight and easy of carrying them off the boat for off season. and my understanding is.. if I get both lIon, i don't need to mess with DVSR.
Don't spend money on overpriced batteries just for the purpose of "taking them out" A charged Lead-acid or AGM battery can be stored in sub zero weather just fine. I will let others chime in with Lithium Phosphate and Lithium Iron batteries, but be sure you have a charging system that can maintain those before installing.
On that note, I made a rookie mistake with my batteries this past fall. I was working on my docking lights and had the power on to test. I got cold and went inside to warm my hands up. Only to find out this weekend when I pulled my boat out, that I never shut the power off and drained one of the batteries. A drained battery and at -30f will kill it. Off to the store to buy an $89, Group 27 Deep cycle battery.
I got 5 years out of my last pair with this procedure, so I see no need in buying a battery that may cost as much as triple that. If I had not killed this one, I probably had two more seasons on it.
Good luck,
Good luck,
Where did you buy these $89 batteries? I'm looking all over and can't find one less than $130 or so. What's your targer CCA? Any guidance would be appreciated.
FWIW, I've had the same batteries in since my purchase in 2019 and I'm finding I'm dropping volts on the lake these days, so trying to get ahead of it.
If you've gotten that many years out of those batteries, why look any further than exactly the same battery.
But to answer your question, our local Fleet supply stores and warehouse clubs have them on sale under $100 quite often. CCA is not a spec most shop for on a waverunner battery in a boat. In a PWC, size is as important, in a boat, any 12v will have adequate CCA for these light spinning engines.
My local L&M Fleet will sell 12v Marine Starting batteries for $85 with 450-650cca. Their deep cycle version is $89 and does not have a CCA rating. More like 182 reserve capacity minutes.
Costco sells Interstate Group 24 and Group 27 Deep Cycle Marine batteries for similar prices. Sams Duracell versions go on sale on a regular basis.
