Hezi
- Secaucus NJ
- 212S
You are right. Only the positive is switched. Why didn't I asked this here before??? I will try this next time I'm working on the boat which should be this Friday. I just ordered another pair of MX 650 in a kicker enclosure to add to the tower. This is going to face forward and give me the loudness I need when the boat is beached and we are hanging on the sand bar. I took the boat to a JL installer to go over my install and figure out the noise. After 3 hours, all he did was to lower the gain to mitigate the noise. He couldn't find any other issue and blame it on the SW420BT EQ.In your boat the ground wire on the head unit harness should be black, labeled gnd, in pin 8 of the harness with only two or three wires from the headunit to the boat harness. Since it is ground it should not be switched. If you added a ground disconnect I recommend that you never turn it off. Everything should function just as it did before except that you will have a much better and similar path to ground.
Thanks a bunch!
