ezrider
- 252S
Hello all.
I keep our 252S at a dock so it is always in the water. I take it out every so often to keep it clean.
Since I will have to take it out over the next 2 months to winterize it, does anyone have any recommendations as to the best way to clean the hull from all the buildup from being in the water? I have a pressure washer that gets most of the buildup. However, there is always a little leftover. Is there something I should spray on first that will help get everything off?
I specifically want to make sure everything is completely cleaned off before I store it for the winter. Fortunately, I found a temperature controlled facility that I can keep it at a steady 65°F.
Thank you for the help.
