Bilge <radio, horn not working>
mamaha
I have a 2007 Sx 230 that starts fine but bilge, radio, blower and horn are not working. The accessories fuse is not blown. Idea? Thanks
There should be an accessory fuse on the rear bulkhead in the battery compartment.
Have you done any work requiring you to disconnect the battery? Is it possible there is a ground wire left off or broke.?
Thank you—I will check that
@mamaha
glad to have you on board, do you have electrical at your helm, back lights, courtesy lights ?
my first thought also is the accessory fuse near the battery, that or if you normally disconnect the battery a wire didn't get reconnected.
then check 39/40 as posted above,
be sure to look at the link below in my signature for common issues with your model boat,
sorry, just rereading your post, when you said the accessory fuse was not blown, was this the one next to the battery you checked?
have you done any electrical work to the boat since the last time it worked correct? do you normally disconnect your batteries between outings?
I recall all the breakers in the drivers console being fed from the same wire on my 08. It may be the same for you. If you can follow the wire to the back of the boat you should be able to find any other inline fuses or other impediments to the normal flow of electricity.
