- Royal, AR
- SX
My wife will be on the ferry next year with my son
Hopefully we will have better water on the way to Bimini next year. We had an amazing crossing today. On the map below the northern line is the return. The dots are spaced out ten minutes. You can see that we covered three to four times the distance in the western ten minute periods on the way back compared to the way there.
I can't express how much difference trim tabs made on the return crossing. I used around 30% trim in both directions. I trimmed up to 75% on the rough days running around the islands. I did not trim much on the way there because I needed to keep the bow above the waves. On the way back 25% to 30% was plenty to keep the bow from bouncing without loosing speed. I tested turning off the trim several times. Each time the family noticed the increased bouncing and asked for more trim.
I would spend on trim and some rough water practice time instead of ferry tickets.
I discussed our rough crossing with several Bimini regulars. Their consensus was that "sometimes you just have to pound waves". Some crossings we will have great water. Other times we will be pounding. Regardless of how you get there Bimini is worth the journey.
