Betik
- Frisco, TX
- SX
i have noticed that my port side center bunk is not making 100% contact with the hull on the rear part ( see pic). The front makes 100% contact ( see pic) The steed side does make 100% contact front and back ( see pic).
The situation remain even after changing the bunk boards.
So a couple of questions.
1. Is this an issue that I need to fix prior to towing 1,300 miles to Florida ?
2. If it is an issue can it be the metallic bracket ? Does shorelader even make them anymore or should I check with the dealer?
