dan144k
- Palatine, IL
Shock absorber in trailer braking system.
This controls the banging starting/stopping noise.
Located between hitch ball and master cyclinder.
Well my trailer been doing this for a few years and I thought nothing of it.
2010 MFI trailer, and never worked on brakes. Brakes were squeaky (lightly). Inspect and found a cracked pad, so I started down the trailer brake repair fun.
Other posts for brakes on this sight list 1997-2000 Kia Sephia and are correct.
- brake pads is correct, I used ceramic. (after you remove the squeaky indicator bar)
- caliper rebuild (from kia sephia is correct,) (I used Oreileys Auto part #15202) cleaned rusty pistons with green skotch brite, look like new.
- calipers (very different brake line size and location)
- rotors used the ones, they still OK.
Then when we went to bleed the brakes, the master cylinder sounds squishy and gurgles so I replaced it.
At this point I found a shock absorber, which I never new existed
- Master cylinder I used, I order mine from trailerparts superstrore. Cheapest next day shipping I could find.
Many Other websites offer these components cheaper. (Amazon post just for simplicity and info)
- Reassembled, Bled the brakes and towed everything 400 miles and working great.
- was amazed to find the shock absorber and it resolved my banging noise, so thought I would share.
- I used info the FAQ and searched "MFI brakes" on this sight for most of my background information, and the information was great.
UPDATE
When bleeding your brakes. If you change your own oil and have the extractor for sucking oil out. Use it also to bleed your brakes. Works great.
UPDATE
