- North Caldwell, NJ
I hate to disagree with you but altitude is most definately an issue here. Specifically density altitude. If you do a quick calculation using your estimate of 1300 feet for your lake and add a 90 degree temperature you get a density altitude of 5147 feet. That means the engines will operate as if they are at 5147 feet altitude where there is less oxygen to burn translating to less power. I'm sure your temperatures are well in excess of 90 degrees also.There are no markings on the engine or side of the boat that indicate HO. But, the recent Yamaha tech (works on jet skis not the boats) swore that it's an HO because the intakes have horn like adapters with the screens on top of them. I really don't know what I have. I don't know Yamaha's markings in 2005. I can take some pictures of the engines to post.
The Arizona Desert lakes are at maybe 1,300 to 1,400 feet. Altitude is definitely not the issue.
Great point. As a former private pilot I should have thought of density altitude, but my DA calculator puts the altitude at more like 3,800 feet using a 90 degree temp, dew point of 60% (relative humidity about 37%) and barometric pressure at 29.82 which is pretty typical in late July and August in the early morning when we ski. Yes temps climb to 100-105 degrees by mid-day, but I'm not enough of an engine expert to know what real impact that 2,500 ft altitude difference would have on horse power or RPM's. Instinct tells me I'm not loosing 1,000 RPM over DA, maybe 100 or so.I hate to disagree with you but altitude is most definately an issue here. Specifically density altitude. If you do a quick calculation using your estimate of 1300 feet for your lake and add a 90 degree temperature you get a density altitude of 5147 feet. That means the engines will operate as if they are at 5147 feet altitude where there is less oxygen to burn translating to less power. I'm sure your temperatures are well in excess of 90 degrees also.
I did have to throw in a guess factor for barometric pressure and relative humidity but using your figures I get 3899 feet, 4200 feet if the temp goes to 95 and 4497 if your temp reaches 100. You know better than I as to the temps you boat at. I would continue looking for other contributing factors such as the oil soaked air filters you found and possible incorrect or improperly gapped spark plugs but given the fact that both engines are experiencing the exact same results would lead me to a more global issue such as fuel or environment. Keep us in the loop.Great point. As a former private pilot I should have thought of density altitude, but my DA calculator puts the altitude at more like 3,800 feet using a 90 degree temp, dew point of 60% (relative humidity about 37%) and barometric pressure at 29.82 which is pretty typical in late July and August in the early morning when we ski. Yes temps climb to 100-105 degrees by mid-day, but I'm not enough of an engine expert to know what real impact that 2,500 ft altitude difference would have on horse power or RPM's. Instinct tells me I'm not loosing 1,000 RPM over DA, maybe 100 or so.
GPS or dreamometer? When I had a paddlewheel speedo I reached 50-52 all the time. It over estimated speed by 4-6 MPHI see ppl talk about not being able to hit 52 when I can hit it all day long with a boat full of ppl and equipment. It doesn't plane as easy with all these fat ppl on my boat but once it planes out nothing will slow it down. Even with a boat full of ppl my wife jerks me out of the water when I slolum ski and cruises at 45 (around 9000 rpms). I couldn't be happier with any other boat. Best purchase ever! Every other boat I've skied behind I was in fear of drowning before they got me out of the water.
Thanks, that's actually the first thing I adjusted. They weren't going to the stops, but it didn't make any different with top RPM's.Possibly the throttles need adjustment and are not wide open when the levers hit the stops. Cam.
Okay I have the pumps apart and here are pictures of the numbers and the condition (Starboard first 2, Port second 2). They sure look like factory and appear to match the numbers Bruce provided. The only flaw I see is one obvious ding in the trailing edge of the port impeller from a rock. The bearings turn free and smooth on both shafts and are tight in the housing. I also added a photo of the Port shaft that has been rubbing on white nylon bushing where it enters the fiberglass hull. I have no idea what turned the bushing blue.I am sticking with the theory that you have over pitched impellers.
Your impellers should be
Impeller STBD 16.3 DEGREES 68N-R1321-10-00
Impeller PORT 17.3 DEGREES 6B5-R1321-00-00
He did clarify these were not my boat. I researched the impeller part numbers myself for the SRT-1000D engine that I have and they match. They also match what Bruce suggested. I'm confident these are the stock and correct impellers.The page that Txav8r posted with the impeller numbers above was for the HO engines, it does not apply to you,
