swatski
- North Caldwell, NJ
An impeller's pitch, particularly the trailing edge angle, will determine the max RPM (for any given engine/pump).I would think if the impellers were a diff pitch it would still hit the rpms just not the speed. It is a ho correct? Didn't I read that it will hit 9000rpms on three cylinders. Even though I find it hard to believe that both motors are running on 3.
If those impellers are different make/model and /or pitch than OEM, all bets are off.
Same as regular props, really, except an impeller will have a set blade diameter, but the pitch will determine RPM.
