Welcome to Jetboaters.net!
Thanks for that info haknslash. With that said I think I will try that first at home, just loosen the tension on the strap and if it does rise enough to clear the whole assembly then I'll knock out the swap in the driveway, where I would prefer to do it anyway. Like you and others have said, there seems to be unknown variables that pop up and then you're screwed at the dock. I'll let ya know. Thanks again.
Thanks @haknslash. So I was able to swap it out because it raised up just like you said. Here are my pics. Here is my question now though. Is it more important to have the gap closed or the the roller being able to free spin? As you can see in the pic there is a gap in between the center roller? Any tighter and the outer bells do not move at all. The gap doesn’t concern me, since the nut is a nylon locking nut, and my theory is that free spinning is a good thing. So I left it as you see. I also did not use the factory recessed washer since the new Stoltz came with washers. Also I must have lucked out and they have started to wise up because they sent me a bolt with my new Stoltz and it fit perfect. All in all I’m glad I did this, that Stoltz is definitely softer and putting less pressure on the fiberglass gelcoat.
Did you go with the RP-355 3.5” roller? The larger boats typically use a Ultimate 4” and either pry the metal braces or shave a little off each side of the roller to make it fit. I shaved mine down to 3.6” wide to match factory width.
The bells on the sides are ok to spin. They are just there to help center and catch your boat. The roller should have the bow eye resting against it when you retrieve and tighten the strap.
My roller came with bolts, nyloc nut and washers. I’m not sure why some people on here did not receive bolts. Should come with new hardware.
Just an FYI for anyone interested. This is how the Stoltz RP-446 Center Roller (4") and the RP-435 Bells line-up with the 2019 242 hull. I called them and emailed pictures of the fit and they sent me this to try, and a label to send the others back. It's not a perfect fit but far better than the one labeled "for Yamaha Shoreland'r Trailers". Unlike the first set they sent me, the very pointed outer edges of the bells don't put such a pressure point on the hull. Also, I didn't have to pry the mount bars apart like many others claimed to have to do to fit the 4" center roller in, it slid in perfectly with about a 1/16" to spare. The service was great, a guy name Tim helped me and was super nice and helpful. (Trailer Parts, Axles, Tires & Accesories | Sturdy Built)
