Gym
- Falmouth, MA (Cape Cod)
- SX
Sounds like you have a steep ramp @njmr2fan. So your scratches are primarily up by the bow? As I mentioned I transitioned to manually loading using the dock lines and winching the last couple of feet. If that is possible you may want to try that.My bunk boards are worn up front near the bow, not the rear. I try to float on at no wake 1, no power loading allowed by me.
@Williamsone46. It's not the carpeting causing the issue but the dirt and sand it traps both at the ramp and on the road. The plastic (generic term) and hdpe boards rinse clean when launching & retrieving. They act similarily to our anodes as the hdpe material is less noble (softer) than the gelcoat. The issue with these materials seemed to be more due to towing than launching & retrieving.
