I think you should do some real research before you do anything, focus on FEATURES and BENEFITS also materials and total cost including shipping, I would say forget any sales if it is not really going to do what you need why waste your money .
I have buy direct discount pricing on all my steering systems all the time! I also give extra discounts to first responders, active military and retired or disables military.
My prices are so low that cost is not an issue.
Buy the boat ,go out and drive it AS IS do not let yourself get all wrapped up in a sale, see how the boat handles docking and slow speed maneuvering, see how it handles in mid range speeds, towing tubes ,water skiers etc, see how it handles rough conditions, and see how it steers without thrust or in a rapid deceleration situation.
See how guest operators feel driving the boat.
Now keep in mind the features and benefits, after all you have my steering and it probably spoiled you .
Now the boat you are purchasing has a keel and a rudder, the rudder is attached to ONLY 1 nozzle my systems have a patented second tie rod to balance out the system.
Your boat also has a rack and pinion steering helm ,you will notice the travel is twice as far as the boat you currently have.
This is noticeable especially for people coming from a conventional Yamaha helm.
Now you also have the keel and this will make the boat feel slow to respond in high speed turns in comparison to what you are accustom to.
My steering has come a long way in the past 19 years and it is not just an at the dock setup.
It is a high performance system with big super fins that automatically change the influence levels controlled by the position of the hull on the water .
At planing speeds only the fin sections under the nozzle are making contact with the water, and you get to decide how much that is.
When the boat is on plane the planing surfaces under the nozzles between the fins actually help to stabilize the hull in chop as well as reduce the spray behind the boat.
These planing surfaces also help get the boat on plane faster.
Now there is also a special set of top fins that do not do anything on plane as they are not needed but when the boat comes off plane these are submerged and now the boat has 4 fins in the water to control it at the dock in wind , waves, boat traffic etc.
This entire system forms a V configuration and is made to stay above the keel and rudder intentionally so as not to increase the draft of the boat.
And this complete deluxe super magnum AK-19 system costs only $489 all year long at the buy direct discount price. it is also compatible with the AK fangs for an additional 45 dollars.
NO plastic parts no epoxies, easy bolt on installation and a 30 day satisfaction money back guarantee posted on my web site.
And as usual this is only one of several systems available for your new boat plus that price includes free domestic priority mail .
So do your research . Haste makes waste as we all have learned !
