- Norman, OK
- SX
I did that for about a year. I found that putting the large plastic tarp over the Yamaha cover was a total pain in the butt. I was using the cheap blue or tan plastic tarps. Perhaps a heavier cloth cover would work better.There was some discussion a while back about using a cheap, extra-large tarp layed over the factory cover to be the sacrificial cover cover while storing outside. Since sun does the most damage, the idea is to let the sun beat down on the cheap tarp rather than eat away at the factory cover.
Seems like good logic to me. Not sure it has been proven or even tested. But I got a new cover this summer, so I will probably try the cheap-o-tarp-cover-cover and see if my new factory cover survives the elements better.
I'm currently using this DryGuard cover http://www.amazon.com/gp/product/B003SL89GA/ref=wms_ohs_product?ie=UTF8&psc=1.
It is so air tight that I installed two passive vents, then purchased two poles to hold the vents up so it is a quicker/easier anti-pooling setup for our mostly dry summers here in CA. I'll use the OEM anti-pooling setup in the rainy winter months. This is what I would recommend: http://www.amazon.com/Vent-Cap-Adju...sim_sg_15?ie=UTF8&refRID=1NMFSKADNKJCBM3WYWK7
The Yamaha boats have a lot of boat above the bond line. I had to buy the 24' cover for my 21' boat. I still have a short section, about 3-4', where the cover doesn't reach the bond line. I keep that to the shady side where I store my boat. The cover's length isn't a problem, width is the problem.
Sorry I didn't notice this post. I'll try to remember to take some photos tomorrow and post them.You wouldn't happen to have any pics of that cover on the boat would you? My one year old OEM cover is already on its last leg since I am forced to store outdoors and when I purchase a new OEM for trailering I might consider a "cheapy" for storage. I'd have to modify it for my AR, but sewing doesn't frighten me too much.
View attachment 10100 View attachment 10099
OK, I can sleep again knowing she is resting comfortably under a proper, fitted cover again.
Incidentally, this cover appears to be made of heavier fabric than the first one. I thought it was just wear, sun, or an illusion until I compared the new and old stuff sacks that came with the covers. Neither has ever seen the sun nor been exposed to wind nor weather of any kind. The new one is definitely heavier.
I guess I have no excuse to thumb my nose at the HOA any longer and should take her back to storage... (sigh)
