HangOutdoors
- Royal Oak, MI
CE Smith Trailer Post Guide on with LED Lighted Posts 60"
Well I am putting these on the trailer this evening and I have them mounted as far back as they will go. I have the covers for them as recommended. They are about an 1.5" away from the side of the boat. The boat is an 2020 AR210, with supplied Shorelandr trailer. I mounted them above the beam. My concern is that the end that goes under the boat is about 2inches or so from the boat but below the bunk. It seems awful close. Is this Ok? Or should I cut some off with a hack saw. I just don't want it to hurt the boat if I come in a bit funny.
Also,
I was looking at the few pictures of other members who have installed this model and I am curious who you did the wiring. I slipped mine down between the PVC and tube but then I need to run it under bottom tube and then around the back toward the light for the tap. Seems a bit hokey and sloppy with zip ties. I would definitely appreciate any and all suggestions.
![PostGuideProximety1.jpg PostGuideProximety1.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/119/119065-d924d2163490f284b69a35b9c3aa2391.jpg?hash=2STSFjSQ8o)
![PostGuideProximety2.jpg PostGuideProximety2.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/119/119066-ef7406c95f31f3a6196ec7e558defd85.jpg?hash=73QGyV8x86)
Also,
