    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
Cheaply Adding Bluetooth/Alexa to existing stereo
kmacbham
So first time posting… this may already exist on here somewhere but I have a Yamaha 2010 sx240 ho . I came up with a cheap (under $30) way to add Bluetooth to any existing stereo with 3.5mm audio input. Also can add Alexa if you want. I used the Roav Alexa charger because I had one (it’s no longer made). The one I. The link below is a suitable replacement. You can use a cheaper usb cigarette power plug if you don’t want Alexa to just power the Bluetooth piece.
Alexa for cigarette lighter
USB Bluetooth to 3.5mm audio stick
See pic:
