sstegh
- Menomonee Falls, WI
- Boatless
- NA
- Other
- NA
I don't see what that would be a problem, or am I missing something?
Just might need to get some info from you so they could look up what they did to your boat.I don't see what that would be a problem, or am I missing something?
It stays on my floating lift in the water. We did have a thunderstorm the other night before this happened.Just for chance: where do you store it? Had a lightening strike reported once that had odd effects like that...
http://www.ebay.com/itm/Yamaha-Outboard-Jet-Boat-WaveRunner-YDS-Diagnostic-System-Cable-Kit-/251420817975?pt=Boat_Parts_Accessories_Gear&hash=item3a89d93a37&vxp=mtrPaul, What was the program called on Amazon? I see the cable but not the program. Thanks, Ron
Mine is a 2012 SX210 with the "drive by wire" servo activated throttle bodies and it worked fine. Cannot be 100% it will work but it should. To use it I had to disconnect the gauges from the engines and plug it in at the engine compartment. I could not get it to work from the diagnostic plugs behind the dash.Will this work on 2013 and newer boats? Mine has electronic throttle bodies.
