haknslash
- Lake Martin, AL
- Moomba
- Other
Well it did pop out once like I mentioned earlier so perhaps there is a small bend causing it to not line up properly. In any case it just seems like why not try a pin with stronger metal, possibly easier to install/remove and see how it goes? You can get them in 3/16" diameter so that's not much larger than the existing 1/8" diameter hole you have to drill for the EZ lock. There is plenty of metal material still there to not weaken the arm IMO. I measured the width across the cleanout port area and I would need a 1 1/2" grip length for the pin so that is standard parts bin and will be readily available anywhere. I'm going to try and see it I can make it fit which I think is possible. Just wanted to try something different and share my thoughts on my experience.
