2kwik4u
- Georgetown, IN
Been doing some research on a new tow vehicle. My 2006 Trailblazer SS has some issues I'm not sure I want to fix, and my wife's Traverse is only front wheel drive. The SS tows well, but is a 11yr old truck with issues. The Traverse tows much better than I expected, but the FWD only has me concerned with some of the local ramps that are notoriously slippery and steep. I've watched other rear-wheel-drive trucks struggle, I don't even want to try with her FWD vehicle.
Boat in question being towed is a '17 AR190. I've read several folks comment that thier boat only ran about 3,500 lbs fully loaded on the trailer. The Tacoma is rated at 6500lbs, so I don't think that is a problem. Looks like others here are towing the 23/24ft boats with this truck with good results.
Saw an ad on TV this morning for a $299/mo lease on new Tacomas and got to reading. I'm still super early in the process, and still need to drive/look at them, as well as run the actual numbers however the preliminary look is encouraging.
SO......here's the question......The Tacoma is offered in a V6/4x4/4door MANUAL transmission configuration. I've always preferred a manual transmission to drive, but have only ever towed with a manual transmission once. That was my father-in-laws 39ft 5th wheel camper hooked to his F350 with a manual transmission. It looks good on paper with less overall maintenance, and an increased "fun to drive" factor. Initial purchase price is $2k lower as well. Obviously the hardest part will be getting the boat out of the water, however a hand brake and experience with the clutch will help there. I've read where some Tacoma owners have rigged up a way to engage the low range on the transfer case and not engage the front axles, allowing for a 2-LO configuration that might work well for getting the boat out of the water.
Any thoughts from boat owners? Anyone out there towing with a manual transmission? Any input would be greatly appreciated.
Have an appointment to go look/test drive the trucks tomorrow evening. Anyone think it's out of line to ask to tow my boat behind their truck before making a decision? I would think if it came to that point I would have already agreed to the truck and that would just be a condition of sale. Any thoughts on that aspect?
