the MfM
- Other
- Other
- Other
And is it me or does every thread get better when @ClemsonTiger starts poasting?
Well, I like to think so!And is it me or does every thread get better when @ClemsonTiger starts poasting?
You and I have far different versions of "better"And is it me or does every thread get better when @ClemsonTiger starts poasting?
The outboard and io can use trim. Trim is highly useful and makes a huge difference in the way the boat rides. Trim trabs are crap compared to actual propellor trim. They both have the most control in reverse. If you get stuck, you can trim up, and you get some early notice its too shallow before you get stuck. V drive and inboard can get stuck hard. Same with a jet if you can't see through the water (muddy or dark). Between outboard and io, the outboard is the clear winner. You can trim it out of the water, and the steering is above water.So whomever said "there's no reason to buy a sterndrive".....I agree. V-Drive, Jet, Outboard, Direct Drive all have better attributes IMO than a sterndrive. I still bought my first boat with one, and the industry sells a bunch of them, so clearly someone likes them.
I agree with o/b winning over any i/o - anyday. However, trimming out of the water completely is just not feasible, the lower unit still hangs down under the hull (in any conventional o/b).Between outboard and io, the outboard is the clear winner. You can trim it out of the water, and the steering is above water.
I'll give you control in reverse. The rest, meh. The only reason I've ever seen anyone trim up is for shallow water, or to attempt to get more speed. Typically shallow water is at low speed, and high trim leads to porpoise-ing unless the load is well balanced. Can't run either an OB or I/O with the outdrive trimmed out of the water. Aside from the lack of traction for the prop, you have a cooling water supply issue when you get those intakes dry.The outboard and io can use trim. Trim is highly useful and makes a huge difference in the way the boat rides. Trim trabs are crap compared to actual propellor trim. They both have the most control in reverse. If you get stuck, you can trim up, and you get some early notice its too shallow before you get stuck. V drive and inboard can get stuck hard. Same with a jet if you can't see through the water (muddy or dark). Between outboard and io, the outboard is the clear winner. You can trim it out of the water, and the steering is above water.
+1I was sooooo confused. Then I saw the link at the bottom to show ignored content. I foolishly clicked on it. I understand the posts now and have reaffirmed my decision to ignore that person.
Very interesting!DJC Marine Technologies has developed 2 new intake grates, both patented. If anyone is interested in checking them out they can be seen on www.repellergrate.com Contact us with any questions, Dan would be happy to discuss our products with you!!
