Ronnie
- SF Bay Area
- Limited S
I’ve fogged my engines a few times before but nto anymore, it simply doesn’t get cold enough where I live to justify the effort and expense. Now I just fill the fuel tank, stabilize the fuel and put damp rid containers throughout the boat to winterize it. The fuel stabiles will cost the cylinder walls if it’s added before the the last use. I also put the anti pooling poles in under the cover, it doesn’t snow here but it does rain occasionally. If I was concerned about surface corrosion I would coat the surfaces of the engines with wd40 or crc, but I’m not so I don’t. I haven’t experienced any post winter winterization problems ever but fogging had me replacing the spark plugs every year instead of every two as a normally Do now. I almost forgot, my batteries are on an onboard charger maintainer whenever the boat and waverunners are not in use and stored on the side of my house, so five to seven months straight during the off season.
