rockinthesuburbs
- Saratoga Springs, UT
- 195S
Hello - new 195S user here.
I was getting a USB Overload from my radio the last trip and then the Connex screen showed lock icons next to all the input sources. A little digging on the forum showed another user with a similar issue being the fuse blown on the control unit on the swim platform. I removed the radio and found the USB plug not fully seated with some corrosion/rust (explains the overload). Further inspection shows similar issues in the satellite radio port (not currently used) and the antenna as well as feeling damp to the touch. I unplugged the unit and water dripped out of the radio as I was pulling it out. The fuse looks good and I don't see any water or corrosion in the main cannon plugs/power section which is good. I did see a little section on the corner of the LCD screen that I hadn't noticed before either which is concerning.
My plan is to try and clean out the corrosion as best I can and then let it dry out overnight and try it in the morning to see if I can connect to the radio. Any suggestions on what else to do? I'm also going to contact the dealer but I doubt a radio would be in stock or a priority fix. Thinking an after-season repair item, however, that means going without music unless I get a temporary unit installed. Are there better receivers I can look at? Thanks!
