Cover Snap Button Replacement
fabian
Toms River
Our 2020 AR240's snap on cover lost many snap buttons on the canvas last season. Is it possible to put new snap buttons back where the old ones fell out? If so what size button is required and where can I get them? Any special tool required? Thanks in advanced for any help.
If they fell out, you need to check the backside of the fabric, which either was folded over to create a double thickness, or you'll need a bias backing material, and a snap install tool.
Thanks for the info, which size snaps would i need to buy or are they all the same standard size?
They are standardized, however different manufacturors products may not fit properly together.
We currently use DOT snaps. Size 1 using chart above is commonly used size.
@Troy JK Your link is dead now. Can you specify again what you bought and did it work?
I had a few snaps pull through in a recent storm and I'm trying to figure out what size snap I need.
