Crank operated trailer tongue jack dolly. Genius!
utahrd
holladay, utah
very cool.
spaz1868
Lake Lanier, GA
This would be great for keeping a boat in an angle in the garage.
dan144k
Palatine, IL
Very cool indeed. I purchased a less expensive cheaper version a few years ago and ended up returning it.
(info I posted on other site regarding similar product)
Tow Tuff RTF-1500. name and model sold as on amazon for $206 and free shipping, looks like same product. Maybe cheaper for some people with tax and shipping depending where you live. I ordered one, easy to return at amazon of I am unhappy.
edit: I did not have my boat when I received my unit so I hooked it to my van hitch and pushed my van around the driveway to test. I decided to return the unit. All the stress was put on a 2" piece of metal. The design concept was great and it did push my van around, but I did not see the product lasting for several years, so I returned it.
Maybe the american made unit is a more robust design?
Big Shasta
Panama City Beach, FL
Awesome Idea.
DieselCamel
Punta Gorda, FL
World Cat
I own the trailer valet. Works fairly well for me. But I just use it too go about 25 feet as I have to unhitch the boat and lower the tongue to fit it in the garage.
txav8r
Lake Ray Roberts, Texas
It is a very interesting idea. It is very big and bulky however to be a dedicated trailer jack. An added benefit it seems is as a trailer brake, if...there is enough tongue weight to keep it from dragging. Many times when I have stopped my trailer and wanted to disconnect it either empty or with the boat, the ground is not level and the trailer would roll. So I have to go look for chocks to block the wheels. If the gearing as mentioned, prevents movement, then this is a big bonus. But our jacks mount pretty far back on the trailer, I wonder if that would be a factor in use as it is under the edge of the boat?
utahrd
holladay, utah
can the wheel run in neutral or is it always in gear?
DieselCamel
Punta Gorda, FL
World Cat
Always in gear. You can remove the crank handle as it has 2 crank positions high and low gear. i only attached it when i am putting the boat in the garage as it is pretty heavy. i still have my regular jack installed as well
tdonoughue
The Woodlands, TX 77381
Can you post a photo of how you installed it? Love the idea, but I'm trying to visualize how it would fit with the stock jack...
Ronnie
SF Bay Area
I had the imitation version pushed by cabellas. It was a pos that broke / cracked the first time I tried to use it to push my boat up the driveway. It would have burned that much more if I got hurt, by my own boat as it rolled out of control over me in the driveway. I've heard the real "trailer valet" is great but it was/is also twice the cost at over $400.
sysinu
Park City, UT
So this sounds REALLY cool and I think I might be on the fence about buying one. Not really for my property, but in case I want to get my boat into a tight space on level ground. They have other hand held versions of someone like this (trailer dolly) but if this is quality made it would be very useful for all of my trailers that I want to put under covered storage.
It's not quite 400$ I don't think for the the original genuine version of this product. Maybe 300$
DieselCamel
Punta Gorda, FL
World Cat
This thing isn’t perfect. But in my case it almost is as i have a garage under the house at a 90 degrees to the driveway. So i jack the boat to the door unhook drop the trailer as low as it will go to clear the door and use the valet to get it in the garage. BEATS PUSHING
DieselCamel
Punta Gorda, FL
World Cat
http://www.amazon.com/Trailer-Valet-V211-Silver-Tongue/dp/B007G2IH4Q
tdonoughue
Thanks for the pics. It can go on the other side! <duh>
Would be very handy for when I want to cut a short corner or when the valet has left and I am trying to close the door, only to find out that he didn't back it in that last 1/8"...
DieselCamel
Punta Gorda, FL
World Cat
it can be mounted on either side of the trailer as well as there are posts to connect the crank handle on either side so mounting is pretty universal
Ronnie
SF Bay Area
Here is a link to a yjb thread on the subject. It's two years old (back when the valet and the imitation version were relatively new and still $400 and $200 respectively) but the information is still good. There are pics and my review of the initiation version on the page the link is to. On the following page there is a yjb user review of the actual trailer valet. It's from dprhends who may be @jetboater4life here. I recommend you read his review before you hit the order button on a trailer valet. The imitation is no longer available from cabellas, I assume it was that "good".
http://yamahajetboaters.com/forum/viewtopic.php?f=1&t=54292&hilit=Trailer valet&start=30
Ajax
St. Louis MO
