veedubtek
- Punta Gorda, FL
- Scout
- Other
I'll never complain about where I have to park my boat again...
@Ronnie You are correct. I am dgbehrends on the other site. I've been away from the forums for a while otherwise I would have commented sooner. I would not recommend the trailer valet if you have any kind of incline. For minor adjustments in my garage it works but it is a hassle to use since it takes a lot of force to change the direction of the jack. As another member commented you work up a sweat trying to move this thing anywhere. I haven't used mine much this year since I've gotten good backing my boat into my 3 stall garage at an angle. For hooking up it's easy to move the trailer back and forth, so all I need to do is line the ball up and then I can just slide the trailer forward a bit before dropping on the ball. If I need to pivot the dual axle trailer side to side then I break out the trailer valet, but it's a chore. I have the 212x and the trailer valet seems to be maxxed out. The paint is scrapping on the shaft of it and it just looks unstable when lifted up higher. I'm a little nervous that it will fail on me, so I always leave my other jack just an inch off the ground ready to catch the trailer. I would caution those with the bigger 24'+ boats that have a little more tongue weight. Unless all you need to do is a 90' degree turn into a flat garage. I would look at a powered mover or front hitch first.Here is a link to a yjb thread on the subject. It's two years old (back when the valet and the imitation version were relatively new and still $400 and $200 respectively) but the information is still good. There are pics and my review of the initiation version on the page the link is to. On the following page there is a yjb user review of the actual trailer valet. It's from dgbehrends who may be @jetboater4life here. I recommend you read his review before you hit the order button on a trailer valet. The imitation is no longer available from cabellas, I assume it was that "good".
http://yamahajetboaters.com/forum/viewtopic.php?f=1&t=54292&hilit=Trailer valet&start=30
