Grover70
- Ponte Vedra, FL
- FSH Deluxe
Hi fellow boaters....
It doesn't happen too often, but when it does, I try out different tacks with differing results while crossing the wake of a larger boat from astern.
You know what I'm talking about. The boat I'm following may be 30' feet in length, sits low in the water and leaves this huge wake behind it. I approach the wake at a steep angle (near 90 degrees), gun it, and occasionally ride over with without incident. Other times, and I think it's when I'm at too shallow an angle, I pitch and roll and have to fall back to try again.
Would anyone have some advice I can apply to my current system to make passing over wakes from astern less of a roll of the dice and more of a confident maneuver? Not much online I have found that helps me in this type of navigation.
Many thanks!
Many thanks!
