Custom SwimDeck Ballast Bag project
Would you be interested in this type of bag for your swim deck?
  • Yes
    Votes: 54 76.1%
  • No
    Votes: 4 5.6%
  • Maybe
    Votes: 13 18.3%
  • Total voters
    71
I don't have Ridesteady but the way other systems work was once you set it you can nail the throttle WOT all you want but it will not go beyond the desired/set speed. @swatski can you confirm?
Yes, that's the way mine works. You have to give ridesteady enough room with the physical throttles to do its work. We were at 10mph and I rotated the ridesteady dial to 11mph, and the display asked for more throttle. Since I had already moved the throttles to WOT, there wasn't any more throttle to give. I believe the ridesteady wants throttle room beyond what it thinks is necessary for the speed requested, so it can handle and predict overshoot, etc. I'm thinking there was probably enough throttle left to go faster, but maybe not as much as it wanted, so it decided not to. I'll test next weekend with the ridesteady off and see what happens. The other thing that's interesting is that both @nate kennedy and @Bill D have weight forward of the windshield, where as I none when I ran into the issue. When I moved people to the bow, with no other changes, I could speed up if I wanted to. So I may have just had the port side stern too low in the water... the bow was straight up.
Was there going to be a slight redesign or do we think sticking with the original design is the way to go?
Still too soon to tell, but with @Scottie getting a second chance to fill his and have success I think we may be good.
I'll say this. With the bag filled properly, the current handles are in the perfect spot for tying the bag to the lower tow point. If the handles were higher, you'd have to tie to the tower or some place else, which I don't think is ideal. You can see how I have it tied in my pic. Personally, after yesterday, I wouldn't change it. Just my 2 cents.
@Scottie Thank you for sharing, your posts are very useful.
I'll add this:
  1. With RideSteady - it is what you said, TTBOMK; I don't think you are hurting the system when maxing out and it keeps asking for more throttle, it's just annoying I guess
  2. With my 240 I have also reached the point of too much ballast in the back wherein I could no longer come up to wake surfing speed of 10-11mph; I do not remember how much weight did it take - but it was something truly ridiculous -and way over 3,000lbs (I will search the info later)
  3. I could overcome this situation by either moving ballast toward the bow, or by (temporarily) deploying trim tabs - and, interestingly, I only needed to blip those tabs down "to get over the hump", once I was going 10+mph (in some semi-planning mode?) - I could retract the tabs back completely without loosing speed
  4. I would think that you may benefit from the L13 cones if getting up on plane continues to be an issue, or if you feel you are "plowing" through the water at high RPM but barely moving forward; those L13 will increase your pumps' efficiency and generally can improve hole shot quite a bit
I have ordered the custom 242 bag, hope it does the trick. I know people have tried wake shapers without any success but on the 240 forum there is someone that uses the ronix shaper with success they say. Any thoughts?
Where did you order the bag from?
I have a Ronix wake shaper I will sell for $250 shipped. Been on a boat 3 times.
That is @Williamsone46
He has posted good up-to-date info in his 242 thread.
Thanks @swatski , I've used the XL Ronix Wakesurf Shaper on my 2017 242X and loved it. I've seen the standard sized used on 19'-21' models and worked great, noticeable difference with and without out it. I ballasted the port and starboard tanks 100% and would drive straight and would be able to drop the rope no problem. Sorry I haven't got any good videos or pictures.
This year I'm going to try Ronix's new Wake Shaper 205 Hollow Concave and see how it works. It's even bigger and a steeper angle.
I ordered bag from barefoot, I am a dealer for them up I'm B.C. I am a motorsports dealer but started selling some watersports stuff this year.
Did some testing yesterday with the bag. First off there is going to be a learning curve on filling this bag. It filled kind of strange so when full it was a little sideways on the swim deck. So in the circumstance air flow to the engine was a non issue. I did have to tie it down different coming back to the tower because of this. Other then that I think when I have it fully on the seat the handles are in a good spot.
So the 870 being on the swim deck corner was a VERY GOOD thing. I didn't have to run my top of the seat port bag. I ended the day with port bag 110%, ski locker bag 25%, and starboard bag 50%. They wave looked to have amazing push. I think I am going to have to put some weight in the nose now to lengthen out my pocket. This is also using the universal wedge so it is looking promising folks!! Still more tuning to do when a surfer actually gets back there but it is a winner in my book!
What is the universal wedge you speak of?
Started a new thread but 21 ft and 24 ft bags in stock now.
The custom Fat Sac for the swim deck, wake wedge (on top of my custom 3x800lbs built-in ballast) = we are getting somewhere, finally.
About freaking time! Needs some tweaks but getting close.
image.jpg Bag on swim deck , no other ballast except two adults sitting on the port side !!! 2010 ar240
The waves are looking good!!
@swatski Are you at Bull Shoals ? I think we are going to detour over there a few days after our time at Table Rock.
