Custom transducer mount on my 2024 222SD
bigphil
222SD
I didn't really see any mounts that I was in love with so this is what I came up with. Printed in ASA filament...may do resin depending on the results. I haven't finished the install all the way and need to fine tune the two bolts length that mount to the ride plate. Overall quite pleased with how it turned out. I might drop it down another .25" - .5" depending on side-vu results. Won't be in the water until next Monday/Tuesday for the first test. Transducer is the Garmin GT52HW-TM. Should be very easy to adjust the dimensions for other transducers.
Nice! Interested to see how this impacts the steering (drag) on the hull potentially causing the boat to pull in that direction.
We'll see but I don't anticipate any noticable difference. Thru hull transducers fairing blocks look just the same. But... I'll report any issues I encounter.
I was able to get the boat out in the lake today and the results were great. I didn't notice any decrease in handling or any pull to one side, with the mount installed. The water was a bit rough today and with 5 adults and one child I was only able to get up to 45 mph. I usually top out around 50 mph. With that said, I do have a thought for a bit different mount that I think will be superior to this one. I'll design it in a few weeks once I'm back from camping.
