Damaged Transducer
EastonRob
Tred Avon River, MD
On Monday I was in the kayak under the boat while it was on the lift and noticed what appears to be a damaged transducer housing. Not sure when or how this happened, but it's kind of easy to miss with the remaining epoxy there. Sorry, the lighting in the pics isn't great.
Any advice on replacing or repairing? If I replace, do I seek to replace with a stock unit (not even sure what that is on a '21 FSH 255)?
I'm not sure how much risk this represents for continuing to use in this condition. The rest of the mount feels pretty solid, but still...
JASmith
Minnesota
oh man thats awful, it had to be a collision of some sort. It's on the front of the ducer it seems?
It doesn't look like whatever it collided with damaged the hull at all, so my finger in the air guess would be trailer bunk maybe?
EastonRob
Tred Avon River, MD
So I had a few minutes and tried to find the transducer from inside the boat. It's stern-side of the starboard engine inside the engine compartment. It's an Airmar 20 Degree tilt transducer, model number B148-20, part number 31-751-2-01. I called Airmar and spoke to a friendly guy that said Airmar makes these for Navico (Simrad), so technical support goes to them. BUT, he was able to give me the part number for the fairing block, which is the damaged piece. That p/n is 04-816-01. I'm going to go ahead and buy one and (~$26) and figure out when/how to replace. It looks like the hardest part would be getting a big enough pipe wrench inside the engine compartment to loosen the bronze nut. That and getting the rest of the old fairing block and epoxy removed.
Just for reference in case this helps anyone else.
EastonRob
Tred Avon River, MD
I posed this in the electronics forum on this site, but I'll do it here too. I'm looking to go ahead and fix the fairing block. You can see the damaged block on the hull in the original post. This requires removing the transducer. This in turn involves removing the big bronze hull nut and then carefully chipping/prying the old, broken fairing block off the hull. I think I'm going to have to cut the transducer cable and resplice it as well, as there's no other way (unless I'm mistaken) of getting the fairing block in the right position. A couple of Q's:
1. Access inside the engine compartment (pic included below) is tight. I think I'm going to need an Airmar transducer wrench. Anyone know if these are all basically the same size? They have different styles, but I can't tell if there are any size differences.
2. Any advice for removing the old fairing block from the hull?
3. I'm probably going to buy Airmar's "splash proof" junction box, p/n 33-035, to rejoin the transducer cables. Anyone have experience with this thing?
Manual calls for Bostik Marine adhesive, so I guess I'll pick that up.
Thanks for any input. I also plan on calling Airmar customer service tomorrow particularly to get answer on #1.
EastonRob
Tred Avon River, MD
If for no other reason than to document my notes, I'll post here what I learned after almost 3 house of Kafka-esque customer support speaking to Airmar, Lowrance, Simrad, Gemco, and finally some not-to-be-named marine parts supplier.
My boat, and I assume others of similar model and model year (2021 FSH 255 Sport E), was supplied with a transducer manufactured by Airmar, but not supported by Airmar (or apparently anyone else). It was made for Navico/Simrad, but nobody at those companies readily knows this. The model number is B148-20, and the manufacturer p/n is 000-13907-001. According to the installation instructions for this model, the hull nut p/n is 02-133-01. That is a fairly common bronze nut used by Airmar, and googling will readily show you a wrench that supposedly fits it. The p/n for the nut wrench, I hope, is 60WR-4. FWIW, you kind of need TWO wrenches: one for the nut, and one to hold the housing still while you turn the nut. Some or all of this MIGHT be accomplished with large channel locks and/or a pipe wrench, but the space down there is tight.
After 90 minutes talking to Simrad he referred me to Gemco (yet another Navico subsidiary). The brusque guy at Gemco was adamant that the wrench(es) I had found online would not work and that nobody makes one for this particular nut, even though google says it does. He did provide me some useful info -- that the nut OD is 2.88 inches -- and suggested I weld/fabricate my own wrench. I have a MIG welder and can do some decent welding. For whatever reason I'm much less capable with metal fab, but it may come to this.
After speaking to Gemco, I spoke to a marine parts supplier in California that sells both of the wrenches I hope may work (even if the Gemco guy says no). After assuring me she could figure this out and disparaging the intellect of people at Gemco and in that region of the country in general, she called me back a half hour later to tell me, "yeah, this is screwed up. I can't figure out what's going on here." What she did do is sell me the wrenches and agree to take them back if they end up not fitting (their normal policy is no returns on tools).
At some point many of us are going to have to replace our transducers, hopefully with something that is supported technically by someone and is compatible physically with the hole in our hulls as well as with our MFD's. They do go bad. I'm not sure why Yamaha chose this particular transducer for this boat, but it was not the best from a maintenance/supportability/knowledgebase point of view. I'm actually considering purchasing one of the ones still left in stock in some place to keep as a spare, but they do cost anywhere from $400 to $600.
Sorry for the rant. Been that kind of morning. Maybe this helps someone else.
