Mainah
- Chapin, SC
- Boatless
- NA
- Other
- Other
The one second delay may be due to minimal draw on the circut to discharge the relay, or there is a capacitor in the mix or it is has to do with resistance. The switch is marked resistive. I would be curious to know the voltage of the wires when not hooked up to the switch vs when they are. Also when the switch is depressed to either side.
